Transformer
Which transformer i should use to convert 500 v ac to 6 v ac :geek:
Hello, and thanks for writing.
You need a transformer with a turns ration of 83 to one. Not sure where you can find that, you would probably need to have one custom made. If a little more than 6 volts is OK on your output, you might be able to find a 480 volt to 6 volt transformer and use that.
