Hi!
Thinking about buying a wav trigger for my mid-keyboard
Just two questions:
If I want to make samples of an organ, can I have the organ sound on NOTE ON and then trigger a RELEASE key REALESE sound on NOTE OFF?
Can I have multiple samples of all notes. For example 4 C wav files, 4 C# wav files etc and let the Wav trigger choose randomly to create even more realism?
Thanks, yeah
- I’m not certain I fully understand the question…are you wanting one trigger to play a sound and another trigger stop that same track?
Polyphony is enabled by default, but you can disable it - have a read through the basic operations here
- Yes. You can have it select randomly from a specified range, and then also there can be ‘banks’ of tracks, so long as they’re properly named/formatted and such…you can also have triggers to select the banks, etc…the User guide goes into a lot more detail
