UART 2 problem on LCP2478
I am currently using a LPC2478-stk from Olimex.
Os: uClinux
With a cross-compiler and boot loader.
I am currently trying to get my sensor connected to the UART2 however I get the following error:
Serial 8250: too much work for IRQ28
I enabled UART 2 by following the steps in:
http://tech.groups.yahoo.com/group/lpc2 … essage/692
The baud rate of the sensor is 57600
How can I solve this problem?
I maybe got an alternative solution. This is using an a/d converter and using the analog pins of the sensor. However the problem there is that i do not know how i can use the GPIO pins of the LPC2478 board.
Thanks in advance,
Remco
