WAV Trigger - Help with Basic Troubleshooting
I recently bought my first WAV Trigger. I put my first few WAV files on to the USB card, connected the card, plugged in the power, plugged in some headphones. I tried to short Trigger 1 to ground as described in the user guide, but no luck. The headphones are working. The power is running. I just can’t get the track to play.
User guide says: “Using a stripped piece of wire, connect the via for T1 with the via for GND (no soldering necessary). This shorts trigger 1 to ground, causing track 001 to play.”
Honestly, I’m so new to this, I’m already at a loss. What can I do to troubleshoot?
I’d start by formatting your SD card and trying some known good WAV files just to make sure the board is working.
Format your card and try the files in the link below.
WAV Trigger test files.zip (1.42 MB)
