I just got a WavTrigger, which I’m now powering with the barrel jack (12v 2A).
The card is in RUN mode.
I formatted a 4GB SD card according to specs and used Audacity to make a WAV file with no metadata.
Output is to powered speaker for now.
Power is cycled after card is inserted.
File is named 1000.wav
When I push the button on the board, the file plays. When I ground the trigger nothing happens. (I understand that the triggers are the inboard pins; the outboard pins are ground.)
I can’t figure out what I’m doing wrong.
Thanks for taking the time to read this. It’s my first post.
