For whatever reason, I cannot get this board to loop, I have tried ever combination of setting using the WTConfig_win_v200b2 and/or WT-InitMaker_120_20161210.
Any advice would be great! I can trigger with both a switch or volts.
I have also tried turning on and off the Re-Trigger option, and the sound keeps adding onto it self (I would like the sound to reset every time it is triggered). Any ideas on this issue as well?
What firmware version is on your WAV Trigger, and can you provide a copy of your INI file?
Hi, I am not too sure, what is the best way to tell? I purchased the unit in Nov 2020. I was able to get the audio to repeat using “Latch”. However, now I am running into the issue where I would like to not only STOP the LATCHED sound, but play another sound as well after the sound has stopped using the same trigger. I know I can do this using Arudino, but I was wondering if there’s a method of doing it in the INI file?
