Hi, I use a wav trigger controlled by midi and all seemed to work just fine!
On my uSD card there are 35 files with flutes (Mellotron Flutes) numbered from 043 to 077and they all sound great!
I give a Program Change command to have the module react to channel 9.
Also there are 53 percussion soundfiles on this disk numbered from 1187 to 1239, and they also play as they should, FOR ONE FILE…
The file numbered 1193 called 1193-Floor-Tom-1.wav is NOT playing.
Things I have checked:
made sure no meta data is embedded in the file.
gave one of the files that is playing correctly the number 1193 (now it was called 1193-Korg-N1R-Open-Triangle.wav).
gave one of the files that is playing correctly the name of the original not-playing file.
checked the midi with midi-ox and it does note-on note-off with 0#29 (that is note number 41)
Could you help me fix this problem?
