That wind storm a little bit ago threw something at my weather station and knocked the anemometer thingie off. Is it possible to just get that piece?
We only sell the whole kit https://www.sparkfun.com/products/15901
It does look like there’s a small bore for that mounting shaft, you could probably use a small piece of rod cut to where it barely juts up from the bottom to help align the 2 sides and then epoxy/glue them back together…just be careful to not get glue on the bearing (inside top half, can be avoided by letting it dry upright)
You can check wh-sp-ws01; could be a close replacement.
