I’m getting ready to mount the weather sensors on my roof. Is there any specific orientation as to north?
I don’t recall offhand which direction the wind vane thinks is north.
The easiest way to determine this would be to fire it up indoors and slowly rotate the wind vane until your software indicates north, then mark the wind vane base with a permanent marker. When you’re outside, just make sure the mark is pointing north.
