Hello, i purchased the wheel encoder kit and the rubber gasket on the magnet came off.
Has anyone had this happen to them?
What glue will work to reconnect the gasket?
Thank you
Thank you
Hi msantos.
The glue can dry out and once that happens, the magnets come loose. Super glue will work but might eventually let loose as well. It takes longer to dry but something like [E6000 would work great and you can get it at a fabric store ,hobby shop or Amazon.
In a pinch, a bit of [silicone sealant works too and you might already have some at home but it takes 24 hours to cure.](Amazon.com)](Amazon.com)
