The getting started guide for my DEV-13321 Photon Redboard says I should be able to power it on by plugging a USB cable from my Windows 10 (1903) computer to the micro-USB connector on the board. The red power light blinks several times but does not stay on. And Windows then warns me of an unknown USB device. I tried asking Windows to search for a driver with no luck. The Sparkfun Getting Started guide has a link to a Photon driver install web page but the link is broken. So far I have not found any mention of this board on the Sparkfun forums. I’m probably not searching for the right text.
I was hoping to wirelessly upload sketches from the Arduino IDE to the board in what will eventually be a location with no easy direct physical access. I don’t mind using the Photon Web IDE as long as it supports the FastLed library and I can use code developed in the Arduino IDE. I’ve tried using ESP8266 based boards like a WeMos D1 and your ESP-8266 Thing but I eventually screw things up and loose the WI-Fi upload capability and have to resort to the USB connector.
Is the Photon Redboard a good robust choice? What am I doing wrong? Did I mess up the bootloader?
Thank you
