I am looking at the wiring instructions and I don’t see mention of any filter capacitor on the output. Every other PS I have seen has one
Why the missing capacitor? Omission? Not needed?
Should I add one? If so what size
Hi saildude.
Filter capacitors are built into the board but if you need additional filtering, you could add a 100uF capacitor across the output if you wanted too.
Thanks Chris
Just ordered a couple and one other question - how do I attach the heat sink to things? I thought I saw some tape at one point but was not able to find it again - or would a small amount of super glue or epoxy also work?
Hi saildude.
There are special thermally conductive adhesives that would be best for this, but a drop of regular super glue or a tiny amount of epoxy would work OK as well. You want only just enough to get the heatsink to stick. (less is better here.)
Thanks - have both superglue somewhere and regular epoxy - an I will remember to have a thin glue line
