Hi all
I had a question involving using an XLR microphone in a circuit I’m making. I’m unsure of how to actually wire up the microphone to receive the signal. It is a 3 pin XLR, so there should be a ground, signal and inverted signal leads. To get this signal and feed it to amplifier do I simply run ground to ground, signal line to the amp and leave the inverted lead open? Or do I need to power the microphone somehow? I don’t have any data sheet or anything like that, I bought it from a pawn shop and used it to record some music a few years ago. It does not require phantom power (at least it did not when I used it). Thanks in advance!
