ZED-F9T UART1 Only Outputs UBX
My ZED-F9T’s UART1 only outputs UBX protocol. When I set other output protocols it will revert to UBX only after a cold restart or power cycle.
I have set the output protocol using the u-connect View/Configuration and the View/Generation 9 Configuration view. After setting the protocol I save the configuration to both BBR and FLASH but after a cold restart the UART1 output protocol is set to UBX only. No other config changes revert like this, only UART1. Anyone know any reason why this is happening?
