Dear Sir/Madam,
I have bought the sensor and try to use the extension code you developed in micro:bit. However, I found that the code is only valid for micro:bit V1. Is it possible to have a updated code for micro:bit V2? Many thanks.
Dear Sir/Madam,
You can either look up instructions for porting it over in the make:code editor…you can also create an issue here https://github.com/sparkfun/gator_particle/issues
