Hello !
My current setup is basically a microbit in a gator bit- with some gator sensors including the gator particle- while i’m mainly programming in makecode. I was able to get the makecode to enable me to read the Heart Rate/BPM of the gator particle sensor, but I am unable to program to read the SP02 (blood oxygen saturation) via makecode. Is this possible? If not, what would be the best method to read the spo2 vaues and output them?
Thanks for your help
Are you not able to get code running at all? or are no values (or accurate values) being read?
So I can get it working as expected for the heart rate monitor, i’m specifically referring to the blood oxygen/sp02 side of it via makecode, which there is no allusion to
Unfortunately, there were significant issues reported with that example. We’ve had to remove it from our hookup guide due to the inconsistencies we saw. I sincerely apologize for the inconvenience, but we can not support that example at this time.
No worries! Thanks for clarifying this for me
