I am using the Gaotr: bit board with the Gator: Particle and the sample code.
The Particle part seems to give data but the heart rate is just random, like 20 for a bit then 100 then 200. It makes no difference if you have you finger on or off.
I have tried tow different particle boards and they both present the same behaviour.
Can you please confirm that the add on extension for makecode is working with these products?
Thanks.
