Now that I had my other PCB passed everything, how I sending another PCB for testing and now it reporting a error again. After reading the logs, I see this
DRC Error - trace to narrow in the top_drc.log, but when I check all of the traces in eagle, they all are in 8mil and don’t seem to find any that is smaller than 8mil. Eagle’s DRC passes the board. I however noticed that the pictures that I got back from BatchPCB is smaller than the one I sented off.
Here are the files: http://www.vipermodz.com/chaser/errors/
Your server gives a timeout, but I’ll check the DRC bot log files.
Cheers,
–David Carne
Um… I didn’t have any problems accessing my server, maybe it working fine now. What did you find so far?
Your server works fine now.
The issue is that you have a tiny “dot” on the copper side of the board - near the 2 pin connector on the left.
If you look closely in top.png you can see it.
Cheers,
–David Carne
I see it too, right above the center of the two pads on the left.
nice find, i couldnt see it at first when the image was scaled.
Um… Are we talking about that little tiny red dot? I have no idea how that got there and you telling me it stopped because of that? LOL
Yup.
That dot is to be drawn into the copper layer, and our FAB cannot draw it.
Ergo, the bot rejects it.
Cheers,
–David Carne
