Hey guys,
I just finished up my first PCB made in Eagle, for a robot. However when I submitted it, it failed the DRC bot. here is the Email:
Thank you for submitting your design to BatchPCB!
Unfortunatly, your design “Walbot PCB” violates our design rules of 8mil traces with 8 mil trace spacing. Your design has now been removed from our servers.
Please double check your layout. Images of the Top and Bottom copper layers are attached. Also attached are logs output by the DRC bot. Traces are colored Purple if they violate the trace spacing requirements, and Orange if they violate the minimum trace width requirenments.
Fear not, you can resubmit your design as many times as you want.
Thanks again for using BatchPCB.
Please don’t reply to this email, the BatchBot will eat it.
https://mail.google.com/mail/?attid=0.3 … b449a3f4f9
https://mail.google.com/mail/?attid=0.4 … b449a3f4f9
unmatched 274X paramblock OFA0B0 - len 6
Macro Name = OC8
Macro Consuming 5,1,8,0,0,1.08239X$1,22.5 [2]
PUSH 1.000000
PUSH 8.000000
PUSH 0.000000
PUSH 0.000000
PUSH 1.082390
FETCH 1
MUL
PUSH 22.500000
PRIM 5
Parse_OK
Arg: 0.0520
Looking up macro OC8 [0x54f140]
Beginning GCODE run
Ending GCODE run
Created 327 polygons
Found 0 errors
Partitioning…
Grouping…
Distance testing
MergeCount: 250
tests: 15897
Board boundaries: Rect: [0.101800,0.101800] → [3.101800,2.301800], w: 3.000000, h: 2.200000
Found 77 groups
lengthdb size 0
DRC Error - trace to narrow
Macro Name = OC8
PUSH 1.000000
PUSH 8.000000
PUSH 0.000000
PUSH 0.000000
PUSH 1.082390
FETCH 1
MUL
PUSH 22.500000
PRIM 5
Parse_OK
Arg: 0.0520
Beginning GCODE run
Ending GCODE run
Created 430 polygons
Found 0 errors
Partitioning…
Grouping…
Distance testing
MergeCount: 324
tests: 25436
Board boundaries: Rect: [0.161800,0.161800] → [3.041800,2.263800], w: 2.880000, h: 2.102000
Found 106 groups
lengthdb size 0
any help would be appreciated
