Anybody notice that the express will show a wifi addr of 0.0.0.0 sometimes?
I turn it on, I get the std 192.168.xx.xx and then it will flip to 0.0.0.0 so you need to menu thru to config again. 3.8 f/w express +
Is it maybe changing the profile that is active? https://docs.sparkfun.com/SparkFun_RTK_ … _profiles/
Don’t think so since it basically just requires me to change the setup back to config to fix it.
Still happens with d3.9. Basically you press the button to get to config, it starts to show the correct ip addr, then flashes all tp 0.0.0.0
