Issues cofiguring RTK Express.
Hi everyone. I’m Having issues With one of two units that i bought recently. I can’t seem to configure via WIFI, even tho it blinks it doesn’t show in the wifi list, while the other unit shows and i can acces. Also i can’t confgure via Serial, because computer don’t detects it, i have installed drivers i tried diffrente cables, Does any one knows what is happening?
What version of the firmware are you running? (https://docs.sparkfun.com/SparkFun_RTK_ … re_update/)
Depending on your firmware version, be sure the config mode is set to WiFi (https://docs.sparkfun.com/SparkFun_RTK_ … menu_wifi/):
https://docs.sparkfun.com/SparkFun_RTK_ … rminal.png
Obviously, you will have to configure this over serial, since you cannot config the unit currently over WiFi.
A factory reset will reset all settings: https://docs.sparkfun.com/SparkFun_RTK_ … tory-reset
You will need serial access, but it sounds like you don’t see the COM port?
Avoid USB hubs. Try a different USB port on your computer.
You have the benefit of having two units so we should be able to isolate the problem. For example, if the working unit enumerates over USB on a given port on your computer, the 2nd, problem unit should as well. Please let us know what you find.
Hi Sparky,
i was in 3.1 because i upgrade when they arrived. I was able to downgrade and later upgrade it, after that everything worked. My issues was i set connect to wifi instead of configure device via Wifi acces point. I tought i had to choose connecto to wifi to be able to stream correction Data via Ntrip server, but seems like i was wrong.
Thank you for your fast response.
Excellent! Glad to hear it’s working. Let us know if you have any other questions.
