I’ve tweaked the reprap arduino breakout board to be more project specific (robotmeter.com).
This is my first time really using eaglecad and I’ll like to have someone look my PCB schematics over before I send them off to the PCB shop (yes, I will be using batchpcb/sparkfun).
Thanks. The unrouted wire is something I should have caught.
Someone PMed me and found the following:
-There is a polygon out of bounds at the top of the board on both the top and bottom layers: I looked into this and can’t figure out what the problem is. I can shrink the polygon down a bit and then the same error just pops up again on the top border.
-"you have a fatal error on the Vcc plane causing part of X5 (pin 11) to be an island. ": I’m confused by this one?
I’m going to reinstall eaglecad. I think the latest version has errors.
