Cold weather failure Jetson Nano
My project is a field robot using a Jetson Nano. Been working on since spring 2019
I can control it at limited distance via ssh (secure shell).
Wanted to test new devices outside…went smoothly for a while then started acting erratic.
Decide to power reset… fan came on at high speed and could not control.
Pushing the robot inside I tried power reset and fan still came on at high speed.
After robot warmed up things went back to normal.
Has anyone been down this road before?
Should I be looking for an industrial sbc and if so any recommendations ?
Also should I be looking at peripherals causing issues?
andyinyakima
