Using Eagle how do I determine the size of my pcb?
Thanks.
Thanks.
You draw a frame in the Tdocu layer. There are prefab frames available, but I have never used them. I just draw 4 wires starting at (0,0) and going from there.
-T
Can’t you just use the frame in the dimension layer (20)? I think that’s what it is for. Eagle certainly clips ploygons inside that boundary. DCR complains when you are too close to the edge as defined by the dimension layer frame.
I think (i.e. not sure of exact details) that the frame in the dimension layer is the center of a 40 mil router track.
Yes you are right. I made a mistage when I said TDocu. It is the dimension layer…
-Tony
