I had some trouble with checking my drill file using ViewPlot, but everything else looked good, so I uploaded it, and it passed DRC. The preview image does not have any markings to show drill points, and I wanted to make sure that that’s normal.
[Image](https://www.batchpcb.com/imgviewer.php?id=8549&check=0c4c295f7805b6df8f6e0ca606498b33)
Most PCB manufacturers don’t like drill holes in the Gerber files, they either reject the files (Olimex does that) or remove them.
Leon
No, I had a separate .drd file.
therethinker: The preview image does not have any markings to show drill points, and I wanted to make sure that that’s normal.
Greetings There Thinker,
BatchPCB DRC bot supplied check images don’t have drill points.
If you are unsure of your submitted design please check it with
a Gerber viewer.
Comments Welcome!
Thanks, I just wanted to make sure, since I couldn’t get it working in the gerber viewer.
