In the layout part of my design, initially I don’t see any errors when I do the DRC check. But, when I’ve added the ground plane (ETCH-Bottom filled either with static solid or dynamic copper), I see bunch of errors when I run the DRC check. I’ve checked everything in the constraints. I’m not quite sure of why am getting the error. If you had similar problem or you know the solution, I would appreciate your help!
krishnanice:
See topics:
http://www.sparkfun.com/cgi-bin/phpbb/v … php?t=3296
http://www.sparkfun.com/cgi-bin/phpbb/v … php?t=2925
ak6dn
