I’m currently using openocd to dump both flash banks of my ARM9 controller. This is the script I’m using:
str9x flash_config 0 0 6 0x0 0x80000
dump_image bank1.bin 0x0 0x8000
dump_image bank0.bin 0x80000 0x80000
shutdown
2 of 10 times this works perfect and this is the output:
M:\OpenOCD\FLASH>openocd-ftd2xx -f str91x_jtagkey_dump_bank0.cfg
Info:    openocd.c:93 main(): Open On-Chip Debugger (2008-02-02 15:00 CET) svn: 279
Info:    openocd.c:94 main(): $URL: http://svn.berlios.de/svnroot/repos/openocd/trunk/src/openocd.c $
Info:    jtag.c:1261 jtag_examine_chain(): JTAG device found: 0x04570041 (Manufacturer: 0x020, Part: 0x4570, Version: 0x0)
Info:    jtag.c:1261 jtag_examine_chain(): JTAG device found: 0x25966041 (Manufacturer: 0x020, Part: 0x5966, Version: 0x2)
Info:    jtag.c:1261 jtag_examine_chain(): JTAG device found: 0x1457f041 (Manufacturer: 0x020, Part: 0x457f, Version: 0x1)
Warning: arm7_9_common.c:695 arm7_9_poll(): DBGACK set while target was in unknown state. Reset or initialize target before resuming
Info:    target.c:233 target_init_handler(): executing reset script 'str91x_dump_bank0.ocd'
Info:    configuration.c:50 configuration_output_handler(): dumped 32768 byte in 1s 859375us
Info:    configuration.c:50 configuration_output_handler(): dumped 524288 byte in 29s 828125us
8 of 10 times this problem occures:
[b]Error:   arm7_9_common.c:571 arm7_9_execute_sys_speed(): timeout waiting for SYSCOMP & DBGACK, last DBG_STATUS: 2c5
Error:   arm7_9_common.c:571 arm7_9_execute_sys_speed(): timeout waiting for SYSCOMP & DBGACK, last DBG_STATUS: 4[/b]
–>My current JTAG SPEED is at 1. I also tried 0.9 to 0.6 but then OpenOCD complains and doesn’t even startup.
Can you please help me?
Regards,
Daniel
