I am getting a ~1 to ~1.5m shift in my collections. Have RTK-Fix using a NTRIP server. Should I switch to an android devise???
The device simply pipes the data into a human-friendly format, android vs iOS only changes the app interfaces a bit (and the required bluetooth mode, BLE for iOS and SPP for android)
If you need a specific feature offered on an android app that isn’t on an iOS one then it might be worth it!
I’m having a similar issue and after some reading I think it’s because point perfect is sending correction in itrf2000. I’d really like to find a way to fix yhat
