Flashing light help
Hi we have these led lights that keep flashing, if you poke the fitting it will stop for a while but then start again, we have replaced some of the units but it is still occurring. It is very disheartening, especially for people that don’t know much about electrics. Any suggestions would be greatly appreciated.
It sounds like you might have a loose wire or connection in the fitting, or a bit of oxide is building up on the leads to your LED.
You may need to solder the LEDs in place to eliminate issues.
