Hi, I received a new GPS NEO M9N with an ANN MB 00 00 antenna.
when powerin it, the pps led turns on once at the start and then does not flash again
I connect de GPS module via I2C to a SamD21 mini breakout. Connection is ok. I use ‘basic nmea read’ example.
I tried the 'reset to factory default example without changes.
the output is as this:
$GNRMC,V,N,V*37
$GNVTG,N*2E
$GNGGA,0,00,99.99,*56
$GNGSA,A,1,99.99,99.99,99.99,1*33
$GNGSA,A,1,99.99,99.99,99.99,2*30
$GNGSA,A,1,99.99,99.99,99.99,3*31
$GNGSA,A,1,99.99,99.99,99.99,4*36
$GPGSV,1,1,00,1*64
$GLGSV,1,1,00,1*78
$GAGSV,1,1,00,7*73
$GBGSV,1,1,00,1*76
$GNGLL,V,N*7A
$GNRMC,V,N,V*37
$GNVTG,N*2E
$GPGSV,1,1,00,1*64
