Good afternoon,
We are using jetbot nano https://www.sparkfun.com/products/16417 and had to re-image. We are now stuck getting the system to boot. And hope you can assist us.
So, we are trying to use the image from: https://sfecdn.s3.amazonaws.com/jetbot/ … v01-10.zip as that is supposed to be most useful. We are doing a team project and this is the image the team is using. So, we want to stick to this image.
We have tried on two different machines to:
Download
Unzip using winzip or 7zip or windows extract
etch using balena etcher to 64 GB or 128GB
All as per the instructions. And all steps finish without error.
However, when using the imaged card, the jetbot nano will boot but will than stuck at the nvidia green image and nothing works.
Later for debugging purpose (to see hw problem), we used the image as on https://learn.sparkfun.com/tutorials/as … rom-nvidia and that boots up fine and basic operations seem to work. But things go wrong at a later stage on pytorch etc.
We need to get back to using the image mentioned earlier.
Can you please suggest what can be done ? Can you provide us an SD card that is expected to work using the sparkfun image mentioned above ? We are in Cambridge UK. Or any other suggestion that we have not tried ?
We urgently need to resolve this .
