Is LPS25HB Waterproof? (Qwiic Pressure Sensor)
[This is the sensor in question. Can the sensing part be exposed to water?
The sensor integration guideline for LPS25HB by the manufacturer [at this link says that a filter membrane can be added to protect the sensor from water. Does the sensor contain this protection?
Thank you.](https://www.st.com/resource/en/application_note/an4672-lps22hblps25hb-digital-pressure-sensors-hardware-guidelines-for-system-integration-stmicroelectronics.pdf)](Qwiic Pressure Sensor - LPS25HB - SPX-14767 - SparkFun Electronics)
Hi @baigyanik,
The sensor package itself does not include a membrane. You would need to add one over the opening (vent aperture) in your enclosure - as shown in Figure 2 in the integration guide.
