I have SparkFun Pressure Sensor Breakout - MS5803-14BA, and I want to place it in a humid environment to measure barometric pressure. I assume the breakout board is not waterproof (there is no conformal coating on it!).
So, if I want to protect it from water/humidity I can put it in an enclosure, but my question is, do I need to put complete breakout board in an enclosure? Or I need to keep the sensor ring (circular metallic ring with white gel in it) outside of the enclosure?
if I keep whole breakout board in a case/enclosure will it sill sense the pressure?
I am looking forward to hearing from you.
