I have finished assembled JetBot but it is not moving when run the basic_motion.ipynb.
I check all soldering point is looks to be ok and reviewed all connection (e.g. pins, etc.) are also corrected.
Is there anything I can check what’s wrong on it ?
Hi itiscorrect,
Which step of the basic_motion.ipynb notebook are you on? Have you tried restarting/resetting the kernel for basic motion? It may be that it is locked up somehow and restarting it may fix the problem. If that does not work, can you please specify where you are in the basic_mtion.ipynb notebook and also take a few photos of your robot? Photos of your connections to the motor driver and the motors will be very helpful to identify if there is a hardware/connection issue.
