Have LEDs w/4 pins and having quite a difficult time soldering stranded wires to each of the pins. Isn’t there a harness or pigtail or something that eliminates the soldering at the LED? I can’t find anything on the site ![]()
((LED product: com-12986))
I wonder if the leads would fit into the JST connector used for Qwiic products?
https://www.sparkfun.com/products/14427
Otherwise, I’ll bet these could work:
Brow is on the right path but the Qwiic connector is going to be a bit too small to accomodate LED leads and the jumper wires might be a bit too big to make good connection.
I’ve tried 4 pin JST-SM connectors withe 4 leaded LEDs and they work really well. Have a look at part number [CAB-14576 for a connector that will work for you. (You will only be using the socket end, not the plug.)](https://www.sparkfun.com/products/14576)
Thanks Gents for such quick responses!!!
TS-Chris: I saw those connectors earlier but didn’t know if they would work. Thanks for the confirmation. Ordering!!!
Enjoy!
