Lesson learned: Via too close to trace
I’m just getting into PCB’ing and thought I’d pass on my recent lesson learned. On the backside of a very simple board, I stuck a via too close to a neighboring trace AND made it a square via instead of a round one. Needless to say, the traces shorted to each other. Luckily for me, the short was relatively easy to spot and even easier to fix (one gouge with a razor blade fixed it).
Lesson learned: The SparkFun DRC Bot isn’t omniscient!
Here’s what it looked like before I took the razor to it:
Your PCB software DRC should have caught it, anyway.
If you submitted gerber files, and the via is actually touching the track, then the DRC bot has no way of knowing they aren’t supposed to be touching…
The CAD program DRC should have found that - was a DRC check not run before outputting Gerbers?
I used the SFE drc file for Eagle, actually. I’m surprised myself that it didn’t catch it.
It must have an error. Perhaps you should contact SFE about it.
