LoRaSerial - STL files for board?
I purchased the LoRaSerial Kit - 915MHz and I want to make a custom enclosure combining these with the RTK Postcard. I can find the enclosure stl files for the LoRa but not the board STL file like I can with the RTK Postcard. Is this available? If not can they be posted on the Sparkfun website or GitHub? Thanks!!
The export seems to have added a couple weird rectangle glitches, but it did export from the .brd files to STEP for me in Eagle that you can use as a scaffold…the board itself looks about right, minus the lipo connector and a few other things (but I suspect this is enough to get ya goin’!)
SparkFun LoRaSerial 915MHz - 1W.zip (132.3 KB)
Thanks - easy to suppress those erroneous solids but it would be very helpful to have the proper size and location of the connectors - USBC, serial and the antenna so I can design that into the housing. Do these exist?
I’m not sure why eagle’s export isn’t populating them…maybe try exporting as some other file types? Or you can open the .brd and it has the measurements; Eagle is free (but will be deprecated in a year!)
But no, not very many have 3D files…but if you have a micrometer you can just measure the unit physically (they’re easy to open up) and get whatever you’d like that way
Thanks @TS-Russell
I opened one up - its complicated enough that I’d be way more comfortable using the real file. I opened up the board in Fusion360 and it still gave me the same results (ie not good enough!). Can I get 3d files of the housing that it comes with? Then I can just measure off that in Solidworks. Thanks!
