LPC-E2294 power via USB
I recently bought this board “LPC-E2294” - switched the EXT/USB jumper to USB side. Then plugged in a USB cable to connect the board to a PC. The Red Power LED turns on for less than 100ms & is solid OFF all the time.
Questions:
  1. It does not appear to be powered properly?
  2. Does is board support powering via USB? If not, what power supply do I need to order (the diameter of the jack is smaller than the most common ones – that are found in other LPC boards from Olimex like 2106 or 2148)?
  3. What flash utility works best with this board? Flash Magic or LPC Flash utility?
  4. Flash Magic shows COM ports – Does it support USB interface?
-Mike.
