I’ve hooked up my breakout and am running Example2_NMEAParsing from the library’s github. I get an initial blue flash on the PPS light when power is applied, but after that there is nothing. The example code continuously prints “Waiting for fresh data”. I have tried moving outside, but get the same result. What steps should I take to trouble shoot?
That example requires a 2nd library; follow the steps here https://learn.sparkfun.com/tutorials/sp … no-library and that should get it goin
I am having a similar issue. Initially I was receiving PPS and communicating over UART successfully, but it stopped working and I can’t seem to get the PPS LED to start flashing again. The board has been unplugged many times, but I was wondering if there is something else I could try.
