New RTK Surveyor bluetooth not seen or connect
Hello, I purchased a new RTK Surveyor kit but unable to see the device on any IOS device. I can see it on my Dell laptop. I will connect for a second then say “not connected”. I can connect via the serial USB port with u-center. Currently running 1.32 and 3.7 on the unit. The bluetooth light on the unit continues to flash.
Also, my understanding there is no wifi on this unit. Is there a way in u-center to adjust the bluetooth configuration?
iOS doesn’t support SPP in BT mode; swap that on the apple device if you are using one https://docs.sparkfun.com/SparkFun_RTK_ … bluetooth/
There are several ways to access the config, see https://docs.sparkfun.com/SparkFun_RTK_ … k-surveyor and poke around
