So I have been trying to set up an RTK Surveyor device using SWMaps on IOS and have run into a problem. This page (https://docs.sparkfun.com/SparkFun_RTK_ … #apple-ios) about using SW Maps indicates you need to switch to Bluetooth BLE rather than SPP. It links this page (https://docs.sparkfun.com/SparkFun_RTK_ … nu_system/) for switching between the bluetooth types.
My issue is this: The system config page has no option to switch the type of bluetooth connection.
The option is simply not there, despite the fact that “The SparkFun RTK devices support Bluetooth Low Energy (BLE) which does work with iOS.” It is not the only part of that page that I cannot find in the system config menu, but it is the one that I seemingly need. I had considered it might just have both active, but SW Maps on my iPhone cannot discover the RTK Surveyor. If you can help, please do.
