My hardware: CC3000 with Redboard.
My software: “Pushing Data to data.sparkfun.com” example - unmodified except for entering my network settings. You can see this sketch at https://learn.sparkfun.com/tutorials/pu … 000-shield.
Problem:
After downloading, when I run my serial monitor, I see the expected network connection confirmations. The first data push returns the full header as expected. But on subsequent pushes, the data is pushed correctly but I don’t understand the response from the server. See below.
Here is the output from my serial monitor.
CC3000 Ready!
Connecting to… eyepee
My IP: 192.168.1.228
=========== Ready to Stream ===========
Press the button (D3) to send an update
Type your name, followed by ‘!’ to update name
[button pressed a first time]
Posting!
Connection: close
HTTP/1.1 200 OK
Access-Control-Allow-Origin: *
Access-Control-Allow-Methods: GET,POST,DELETE
Access-Control-Allow-Headers: X-Requested-With, Phant-Private-Key
Content-Type: text/plain
X-Rate-Limit-Limit: 300
X-Rate-Limit-Remaining: 299
X-Rate-Limit-Reset: 1432006130.059
Date: Tue, 19 May 2015 03:13:50 GMT
Connection: close
Transfer-Encoding: chunked
Set-Cookie: SERVERID=phantworker2; path=/
a
1 success
0
[button pressed a second time]
Posting!
Connection: close
[button pressed a third time]
Posting!
Connection: close
Can someone help me understand why I’m not getting a response on the second and third data pushes? I’m expecting a “1 success” or '0 error…"? I want to get a response that I can parse for alerting the user to an error.
