OLIMEX EP9302 heart bit
Hi All,
I have purchased a EP9302 board from olimex. I can not get any response from the board. Is there anyway that I can understand board is functioning at all.
I would connect a serial cable to the serial connector of the board and my PC/Mac. Connection Speed is 57600 8N1. If you have the right cable you should see the boot messages…
If you don’t se anything you should check settings and the cable
Cable is a null modem cable
PIN2 – PIN3 (RxD – TxD)
PIN3 – PIN2 (TxD – RxD)
PIN5 – PIN5 (Gnd – Gnd)
Regards, f.
Thanks for the help but I do not get any response. Do you know how can I flash bootrom?
