HI, I recently received a Quadrature Rotary Encoder. I am not getting any feedback from the encoder when connected to a position detector system or to an oscilloscope. I tried ordering a new encoder but its backorder. Please help with a replacement unit or troubleshoot the existing unit.
The Encoder I have is - Rotary Encoder - 200 P/R (Quadrature)/COM-10932
Hello ykatbamna, and thanks for posting!
These encoders have an open collector output and don’t actually output a voltage. The outputs both drop to ground when active and you need pullup resistors on the A and B lines to see any voltage at the output. Two 10K resistors to VCC should get you working.
This diagram will show how to connect everything. (Note, the yellow wire does nothing on this encoder and can be left disconnected.)
Hi Chris, Thanks for your response. We tried testing it with the resistors and scopes. We get response from Channel A (Black) but no response from Channel B (White). Channel A reads 5V and gives pulses but Channel B just shows 5V but no pulses.
Oh, that’s no good!
If you purchased this directly from us, please fill out the form on the right hand side of [this page to start the return/RMA process. Don’t forget to enter your SparkFun order or invoice number in the form and if you know the part number, enter that as well. In the Why do you want an RMA? section, enter the URL for this forum post so the returns processor can see what troubleshooting steps have been taken and we can ship a replacement.
If you purchased the part from a distributor of ours, you will need to contact them for a replacement.](Return Policy - SparkFun Electronics)
HI Chris, I purchased the part from Sparkfun. I followed the instructions you listed above a day back but I haven’t heard anything from Sparkfun so far. Is there anything required from me?
Sorry about that ykatbamna, I was out sick yesterday but I’ll get this taken care of for you today.
