RS232-TTL pcb failed DRC
Hey,
I’ve finished making my pcb in Eagle and am trying to upload it, but it keeps on telling me that it “violates our design rules of 8mil traces with 8 mil”. I’ve got holes for standoffs which it is showing in orange, but even removing them it still fails. Eagle and Viewplot and they both come up with no errors, I can’t find what could be wrong.
unmatched 274X paramblock OFA0B0 - len 6
Macro Name = OC8
Macro Consuming 5,1,8,0,0,1.08239X$1,22.5 [2]
PUSH 1.000000
PUSH 8.000000
PUSH 0.000000
PUSH 0.000000
PUSH 1.082390
FETCH 1
MUL
PUSH 22.500000
PRIM 5
Parse_OK
Arg: 0.0520
Looking up macro OC8 [0x54f140]
Arg: 0.0600
Beginning GCODE run
Ending GCODE run
Created 414 polygons
Found 0 errors
Partitioning…
Grouping…
Distance testing
MergeCount: 366
tests: 11756
Board boundaries: Rect: [0.022800,0.018500] → [2.259800,2.168100], w: 2.237000, h: 2.149600
Found 48 groups
lengthdb size 0
DRC Error - trace to narrow
Macro Name = OC8
PUSH 1.000000
PUSH 8.000000
PUSH 0.000000
PUSH 0.000000
PUSH 1.082390
FETCH 1
MUL
PUSH 22.500000
PRIM 5
Parse_OK
Arg: 0.0520
Arg: 0.0600
Beginning GCODE run
Ending GCODE run
Created 107 polygons
Found 0 errors
Partitioning…
Grouping…
Distance testing
MergeCount: 57
tests: 1909
Board boundaries: Rect: [0.141300,0.191300] → [2.136300,1.796300], w: 1.995000, h: 1.605000
Found 50 groups
lengthdb size 0
Top
http://img260.imageshack.us/img260/3919/topiw9.png
Bottom
http://img503.imageshack.us/img503/1623/botfi4.png
Can anyone help me out?
Hi - you have 0 width lines on your design from the drill holes. In the cam section, don’t put the drills into the top copper layer. Put drills + borders into top silkscreen.
Cheers,
–David Carne
Ah, it’s working now, thanks for your help!
