RTK SURVEYOR WON'T STREAM NMEA OVER BLUETOOTH
No messages coming from the Bluetooth port, only streaming to the USB port. Please help.
That is the default mode that it operates in; check out https://docs.sparkfun.com/SparkFun_RTK_ … s-receiver for more info/potentially configuring a bluetooth broadcast message…though we generally recommend using serial radios instead
