Simultaneous Bluetooth and USB output from RTK surveyor
Sparky has been very helpful and has suggested using STRSVR program from RTKLIb to try to get this to work. When Rtk surveyor is outputting through bluetooth, I am unable to connect u- center via the UBox config port on the surveyor: The com port on u- center is grayed out. The last update I can find on this topic is dated 2020 so a bit concerned the info is out of date. I would really like to use SWMaps for the utm output and the radial spatial display in u-center at the same time to assess real time location drift. Any help to get the Bluetooth and USB output to work simultaneously on Rtk surveyor would be greatly appreciated.
You may need to switch BT modes https://docs.sparkfun.com/SparkFun_RTK_ … enu_ports/ The last paragraph points you to https://learn.sparkfun.com/tutorials/sp … d-features to show the location of the internal switches ; you may also be able to use https://docs.sparkfun.com/SparkFun_RTK_ … nu_radios/ depending on the protocols supported by your other hardware
Thank you. Maybe I am making this too difficult. Do u think running a 4 pin to usb cable from the data port on the Rtk surveyor (4 pin) to the usb on my windows computer would work?
Looks like I would need to also switch the data port from Bluetooth to external connection. I’m not sure if this would disable my ability to receive and use Rtk correction data over my smartphone.
https://portal.u-blox.com/s/question/0D … k-surveyor
