SparkFun Jetbot Software Setup
I mistakenly erased the pre-flashed image. I realize now that I needed to read all the instructions on this page first however I’m now ready for the “extra work” necessary to fix my problem.
https://learn.sparkfun.com/tutorials/as … rom-nvidia
Do you have a location to download the pre-flash image? If not, could you provide instructions to setup SD card?
Don’t feel bad, I did the same thing.
I also need a link to download the image shipped in the kit.
The image file we currently have is 64GB in size.
We’re working on a way to shrink that and a place to host it.
The hookup guide is where the link to the image will likely be available so keep an eye out there.
For anyone having this issue, I just updated the tutorial with [instructions on re-flashing your card. Additionally, you can download the image from this [link.](https://cdn.sparkfun.com/large/sparkfun_jetbot_v01-00.zip)](Assembly Guide for SparkFun JetBot AI Kit - SparkFun Learn)
I receive the following error trying to open sparkfun_jetbot_v01-00.zip with Etcher 1.5.56 on Windows 10 machine.
[Window Title]
Error
[Main Instruction]
Error opening image
[Content]
Something went wrong while opening sparkfun_jetbot_v01-00.zip
Error: unsupported compression method: 9
[OK]
Have you tried uncompressing (i.e. “[unzipping”, “extracting”, or “expanding”) the file first? You should be giving it a ~62GB “.img” file.](Zip and unzip files - Microsoft Support)
By the way, just to clarify: use WinZip to unzip this file :slight_smile:
