After configuration of device in Tera Term and turning on displays “ZTP Failed ID: A0B7656BD576”. how can I fix it?
When I try to provision device (inside tera term) it shows “Http response error 403: Device hardware code not whitelisted”
Are you using the steps outlined here? https://docs.sparkfun.com/SparkFun_RTK_ … -band-keys
What version of firmware is it running? https://docs.sparkfun.com/SparkFun_RTK_ … re_update/
I had attached some slides if there is something I have failed.
CONFIG.pdf (595 KB)
It looks like an issue with the keys on the u-blox side; I’ll send a private message with further instructions
