Survey Master 3.x does not support NMEA Device
This is an alert to Survey Master users.
Until version 2.9, a NMEA device could be connected.
As of update 3.0 and later, you will no longer be able to and will not be able to connect the SparkFUN Rtk.
Be careful then if it is the app you use.
That’s too bad. I found that out too. I was so excited to try the CAD Alignment.
Have you ever tried “Landstar 7”? It looks an awful lot like Survey master. I found a demo of the newest, Landstar 8, you can supposedly do 3 months of free trial with either version.
Hello.
Yes, I also use Landstar 7 with a CHC team.
It is very good, but its license is quite expensive.
